Alright, I got my Motor Guard in and finally decided to punch the oil pan, install the hollow bolt, and install the Motor Guard bypass system (59 Vetteman actually punched my pan for me, I just crawled underneath and was a tool passer
Once 59 Vetteman got a small enough hole punched a small wire was inserted in the hole to ensure that there was no obstruction behind. The wire was inserted and there was nothing behind so we were good to go. By the way, the oil pan on the 6.0 PSD is thick walled and you really have to hit the shoulder puncher hard to make the hole large enough in order for the threads to start on the hollow bolt.
Ok, the hollow bolt is now installed. Time to start the install of the Motor Guard bypass.....I got my pressure from a special cap that Oil Guard makes for the 6.0 PSD (see pic). The oil is returned to the pan and I now have an easy to maintain bypass setup that will now drain out overnight and won't be messy to change.
I did have a Frantz installed, but really liked the setup and ease of TP changes that the Motor Guard offered.
Pic of bypass under the hood:
Pic of hollow bolt w/return line:
[ May 08, 2006, 11:01 AM: Message edited by: Go_Hogs_Go ]
![grin.gif](https://bobistheoilguy.com/forums/images/icons/grin.gif)
![- -](http://i63.photobucket.com/albums/h150/shawnwithers/MG1.jpg)
![- -](http://i63.photobucket.com/albums/h150/shawnwithers/MG2.jpg)
