That color was all metal the same as the lube oil filters you notice the top is the same as the.lube oil filters. I believe the plastic cores came with the black Manteca California. Models. To filter lube oil with the black ones remove the plastic and put a washer in the bottom push the paper down against the washer and put on the lid put an orifice at the inlet or use a sandwich adapterThe Australian Jackmaster Classic is working like a champ. No orifice and a Perma Cool universal 189 sandwich adapter. Put a 1/8 inch air tank valve in the lid. With the filter still hot I let air in drains in minutes. In the old days when we used Frantz sandwiches we drilled out the orifice. A pain when the orifice was under the screens.
