Motor Guard filter change
Saskatchewan Canada
Changed the tp roll today after 6 months, 1,000 Km's on this roll, did a lot of local short trips this past winter, in the past have gone 4,000 km's mostly highway, that seems to be the sweet spot, I think anyway. :)
Are you doing oil analysis as well? I installed an M100 on my V10 Excursion and changed the filter every 5,000 miles. After I bought the truck I never changed the oil, just installed the M100 and changed out the full flow.:) It's not driven much now, but has 205,000 miles on the truck and 42000 miles on the oil.:) I haven't done another oil sample since this last report.:)
Are you doing oil analysis as well? I installed an M100 on my V10 Excursion and changed the filter every 5,000 miles. After I bought the truck I never changed the oil, just installed the M100 and changed out the full flow.:) It's not driven much now, but has 205,000 miles on the truck and 42000 miles on the oil.:) I haven't done another oil sample since this last report.:) View attachment 278673
I plan to change rolls out at 5,000 km (3,000 miles) or maximum of 1 year, not sure of the cost up here for a used oil analysis, but I like the idea of a particle count. I save money on buying less oil, roll change is 600-650 mL (2/3 of a quart) Castrol Edge 5W20, If I send oil samples for testing I am sure it would put the costs well above dropping the oil once per year (5 L) , the math wouldn't be mathing, lol. :)
I would have thought that you would check for soot, after reading Blackstone's comments (below) about not being able to do a particle count on "black oil". My test on them checking for soot was confusing and not conclusive on my modifications. I have those results posted as of yesterday.
This is an M100 installed on a Ford V10 gas engine.:)
The plan changed, 5w20 Valvoline Restore and Protect became available at Walmart.ca, so only 700 km on the last roll, the sump full of Castrol Edge was drained 🙁, not sure if I will just change the tp at 4-5k km or refresh the whole sump by dropping the oil, depends on how dirty the R&P looks.
