There shouldn't be much sliding going on in a gearbox, except for the differential and of course syncros. The bearings on the ends of the shafts should be sealed so no oil or mos2 is getting there. The 1.5 isn't a powerful engine that taxes the gears a lot.
get some thermal stickers if you think the oil is getting too hot on your long journeys.
Stick them on the gearbox differential away from the exhaust so you don't need to guess how hot the box gets. That middle sticker from 116 to 154 degrees is what I would put. if nothing colours, I wouldn't do anything but if it goes up a fair bit I'd switch to an xW-110 oil, GL4 rated or even xW-140 if you get to the end of the scale. Also change the oil more frequently. You could also add the moly to your current oil and see if it drops temps...
Millers Oils CRX 75w-110 NT+ Fully synthetic transmission oil is an example of such oils
