I have not used a Bosch spark plug since the 1970s, when they were OEM on my boxer twin BMW motorcycle.
I would only trust NGK or Denso plugs.
Yeah I know you're not supposed to check modern Iridiums but sometimes you have to regap because one plug is listed for several makes. I feel like I went through this on a Kia recently.Not just Bosch, had my work truck in for a tuneup and specified GM oem plugs- it really is worth the time to check gaps before installing as I had to return for a misfire wasting everybodies time.
???They may not indexed correctly. If the gap in the plug faces the cylinder wall, it will misfire. I learned that the hard way.
In laymen terms;???
Please explain what I'm missing here. How can the spark plug gap not face the cylinder wall (unless it is a Wankel rotary engine)? The cylinder wall is 360 degrees around the plug.
In laymen terms;
Indexing your plugs just mean aiming the electrode in the most effective direction and you do it through indexing spacers (essentially aluminum washers that you torque down on). This is a thing in really high compression engines or race applications usually to try and gain the maximum effectiveness of your ignition timing by uniformly pointing the plug electrode gap toward the intake valves. This would not be relevant on the average modern consumer grade vehicle...
The top surface is not necessarily flat - it can be pented or domed. If the plug isn’t centered, the “open” end might be facing back into the head.Oh, I fully understand what indexing plug electrodes means...it is routinely done by NASCAR and Formula One teams on race engines. I am asking how do you index plug where the gap doesn't face any part of the cylinder wall as stated by loneryder in Post #16. He did not say align the gap with the intake valves.
Never mix german and japanese plugs and cars.Use NGK or Denso![]()
Yes, it is a shame lots of things are not the same.Wow bummer. I've always had great life expectancy and smooth running from Bosch double platinum plugs with the twin tips. Could be a fluke. Were any others an issue?
If it's a publicly traded company, you can bet your bottom dollar this is their approach to parts manufacturing.Plus today companies are likely having everything assembled in the cheapest places they can find. Possibly even forced to jump back and forth from place to place for parts and maybe even assemblies?
With some plugs the number of threads can cause it not to be indexed correctly. My indy MB shop uses only MB plugs by Bosch and said sometimes they have trouble getting them indexed properly.Oh, I fully understand what indexing plug electrodes means...it is routinely done by NASCAR and Formula One teams on race engines. I am asking how do you index plug where the gap doesn't face any part of the cylinder wall as stated by loneryder in Post #16. He did not say align the gap with the intake valves.
Understand that ...but what's the difference between them to cause problems mixing? Been wondering this for a long time.Never mix german and japanese plugs and cars.
japanese plugs go to japanese cars, german plugs to german cars.
Could have been handled poorly while still in the packaging. I'm running Bosch double platinum which are OE for my BMW and they've been fine.I got tasked with putting plugs in an 08 BMW X5 with a V8 yesterday. No easy task. Book time is 3.5 hours.
I was extremely careful not to drop the new plugs down the tubes and damage them. I did not check the gap other than looking at them as they said pre gapped on the box.
Got it together and it ran terrible. Pulled the codes and then removed the #5 plug that was one that was now throwing a code for a miss fire.
Found this burned spot on the porcelain. I'm thinking it's cracked there and is jumping to ground there instead of of at the top.
The plugs had less than 1 minute run time on them . At this point I am ready to wash my hands of Bosch plugs all together
Thoughts?
Bosch appear to be OE.I have learned to use OEM ignition parts in modern cars. Pay once cry once.
What is the factory plug?
Autolites copper cheapie plugs in my classics, but that's another story.
The boxes were not damaged and they all had the cardboard protective sleeve on them. If they got damaged it happened at the factory?Could have been handled poorly while still in the packaging. I'm running Bosch double platinum which are OE for my BMW and they've been fine.
