More garbage parts
Apple Valley, California
The 1/3 hp motor that runs the evaporative cooler to cool my house locked up.
It's been growling for months so no surprise there. It's at least 20 years old.
Bought a replacement last night at home depot as there was no other option and put it all back together.
The new motor ran about 20 minutes and quit. Spins easy so it didn't lock up.
Made in Thailand.
New vs old.
Joe Readiness would say, "You shoudda hadda spare on hand" (also jk)
Ya well you know how it is. Atleast it waited till payday to die.
Just got back from HD and the exchange was easy. Luckily I kept the receipt. Last night they had 9 of these motors. Now they had 3 and I took one so 2 left on the shelf.
It takes all of 5 minutes to swap out at least.
It's back together and working.......
My son is a salesman for a large HVAC company in PA. At his location, they stock all kinds of parts for air conditioners, cooling units, furnaces, etc. When I used to need parts, always bought them there. Maybe you can find a similar setup in your area.
Can you return it to HD? If not I'd pop it open to see what you might find.
My last sump pump stopped because of a loose wire on the terminal.
Good luck.
If that is your only method of cooling, I’d buy a window unit to keep on hand for $200.
I’d already have one as I like it cold at night but that would at least keep a room cold if that thing goes down again.
How much water does a swamp cooler use?
They definitely don’t make HVAC stuff as durable as they used to. The PTAC unit in my condo died this year but it was 34 years old! I doubt the replacement will last even half of that.
About 15 gallons an hour is my guess. When running all 3 my well pump has to come on often
