More Fluids To Change?
TN
My car is an '03 Sentra. I did the coolant, oil & filter, and air filter. Are there other fluids or anything else I should change now that it has 63,000 miles on it? It's a 5 speed manual with AC and power steering.
Thanks.
Originally Posted By: tig1
Transmission oil, PS pump, brake master cyl.
Replace the PS Pump and master cylinder?
Yup. I use a turkey baster -- I usually suck everything out the reservoir, fill it and repeat every couple of days. When my quart of PS fluid is gone I consider the job done. Good enough for me :)
OK thanks. I've owned the car since 8/07 but since finding BITOG I want to maintain it as well as I possibly can.
Does Walmart have good fluids for the transmission such as Rotella brand?
Brake fluid can be used in the PS if I'm not mistaken.
Trans fluid for sure. Upgrade to Redline or Amsoil.
And flush the brakes with new fluid.
A turkey baster flush of the PS is a great idea.
At 7 years old, consider a battery. Start looking for sales. You can go longer, but why not get it before it gets you?
NO, Brake fluid can be used in the brake system only (and may be in the clutch of manual transmission), never use brake fluid in anything else.
OK, got ya. Thanks again.
