Originally Posted by BlueOvalFitter
Thanks for the C&P.
Did the ADBV have cuts/slices in it? The inlet holes in the base plate look to have some very sharp edges.
What ADBV? This filter only has an o-ring or gasket at the top of the center tube and is held against the top plate by the coil spring in the bottom. The filter mounts with the base plate at the top and is vertically oriented so no ABDV is needed. I recently cut 1 of these and the can of the filter is very robust.(thick) I went back with the Stratapore version on mine.
Thanks for the C&P.
