And from another forum (RAM Rebel):
The description that comes up on dealer computer states the verbiage from the owner's manual in pertinent part for 2017+, 75w90 MS-A0160, C235 axle. However, it lists the wrong part number which is the previous oil used in the 2016 and below vehicles, which is, 68218657AA (75w-140 MS-8985). The proper part number should be 68340460AA (2017+ 75w90). The dealer did not even have this in oil in stock and knew nothing about it until I showed it to them in the MOPAR fluid catalog. Chrysler made this change for a reason, what I don't know but there is clearly confusion. Just figured I would share if anyone else likes to follow spec. See below excerpts right from the owner's manual for a 2015 and 2017:
FROM 2015 RAM 1500 Manual:
Rear Axle – 1500 Models We recommend you use MOPAR® Synthetic Gear Lubricant SAE 75W-140 (MS-8985). Limited-Slip Rear Axles require the addition of 5 oz. (148 ml) MOPAR® Limited Slip Additive (MS-10111).
FROM 2017 RAM 1500 Manual:
Rear Axle – 1500 Models We recommend you use Mopar Synthetic Gear Lubricant SAE 75W-90
(MS-A0160). Limited-Slip Rear Axles require the addition of 5 oz. (148 ml)
Mopar Limited Slip Additive (MS-10111).
