Molykote Longterm 2 Plus EP Grease
JHZR2
Staff member
New Jersey
I have to replace an ABS sensor on my BMW, and it is recommended to install new sensor with a thin coating of Molykote Longterm 2 or similar grease to ABS sensor and housing.
I can find the Molykote grease, and Im not opposed to buying it, but Im not sure if its anything special. What I can find about it shows:
Key Properties
NLGI Grade 2 - MO based grease with a base oil viscosity of 265 cSt at 40 C, lithium thickened, uses both molybdenum disulfide and graphite as solid lubricants.
Features & Benefits
High load-carrying capacity
Suitable for long-term lubrication
In mixed friction it provides wear protection due to solid lubricants and EP (extreme pressure) additives
Good adhesion strength
Good protection against corrosion
Product Details
Product Type: Grease
Chemistry: Mineral Oil
Base Oil Viscosity: 265 @ 40°C
NLGI Grade: 2
Thickener: Lithium
Solid Lubricant: MoS2, graphite
High Temp: 110°C
Low Temp: -25°C
Color: Black
Not a super high-temperature grease. I am curious if that characteristic is compromised in order to ensure longer life, more corrosion resistance, etc.
An ABS sensor isnt really a sliding, wearing part, so Im not entirely sure why any grease would be necessary, other than perhaps to assist assembly.
Thoughts or recommendations?
Thanks!
Originally Posted By: Imp4
Meh...EP grease...
$13 a tube...
That's kind of what I was thinking. If that $$$.
I also have Schaefer 238 and 274 iirc. Maybe a few others (valvoline cerulean?).
Originally Posted By: MolaKule
I'd go with the higher tack # 238.
Is your take on it that the "longterm" element has to do with tackiness and water resistance versus resistance to oxidation and degradation?
I did confirm that I have a tube of 238 in the garage...
