my 2001 F150 calls for
http://www.fcsdchemicalsandlubricants.co...ategory=Greases
High Temperature 4x4 Front Axle and Wheel Bearing Grease
Required lubricant for 4X4 Ford Light Truck front axle spindle bearings, wheel bearings and U-joints
Lithium complex, high-temperature grease
572°F (300°C) dropping point - will not run off at high temperatures
NLGI grade #2
while at AAP, i found Valvoline SynPower that says it's for U Joints, etc etc., meets NLGI #2 GC-LB Lithium Complex EP Grease and has a range of -40 to 400* F.
will this suffice? I wanted the lower range for the winter and i figured 400 was high enough, even though the ford grease specs higher. thanks in advance.
NLGI grade #2
