Alright, so if I understand correctly most additives serve multiple purposes. Moly is a good anti wear additive, but others are good too.
I must have been confused, so the VI is what mostly attracts people to TGMO? Would that matter if the vehicle is in California and the lowest temps it will ever see is around 35 degrees?
Originally Posted By: Solarent
Here is a great list of the types of chemicals and what they are used for in an additive pack.
For example:
Anti-Wear and Extreme Pressure Additives (Surface Protective Additive):
ZDDP, ZTDC, Moly TDC, Antimony TDC, Organic Sulfur-Phosphorus-Nitrogen compounds, Borates and Borate Esters, Tricresyl Phosphates, amine phostphates, and other phosphate esters, Chlorine compounds, and lead diamylcarbamates, lead and barium naphthenates, sulfurized olefins; protective film interacts at various temperatures and pressures to provide either a plastic interface or to provide a compound which shears at the surface.
In many cases a typical oil will use more then one of the above that work in a synergistic way with each other (for example Moly + ZDDP). Some of these are also multi-functional which means they may do more then AW but also act as antioxidants, detergents etc.
Thanks very much for the read. It was very informative.
Originally Posted By: chubbs1
The only problem I have with TGMO is that there is no way in the world it is not full of VII's. These VII's are not natural thus can leave deposits and shear unlike an oil like M1 0w20. I know this statement will make some angry but I don't think you can argue that a naturally high VI vs an oil with unnatural VII's.
Please note. I am not Bashing TGMO. I am just making the point that just because an oil has a very high VI doesnt make it the "best". There is a give and take. Just as with moly.
I'm sorry, what are VIIs?
