@Skippy722 "They’re designed to fail after a certain amount of force has been applied to them to prevent greater damage."
Yes, break or fail; and thanks for keeping on topic.
If the engine were to run out of oil, the spinning components would seize, and a large torque component would result. We would then want it to make a clean break from the wing.
If the engine nacelle were to contact the ground, the resulting tilting force would damage the wing spewing combustible fuel. We want it to break clean from the wing.
If on takeoff or landing the engine were to make contact with a ground obstruction, we would then want it to break clean as above.
