Can't wait until we get to servo/anti-servo tabs!
Thanks, I have modified question #18 to reflect that.The 747 has six individual spoiler panels on each wing. The 767 has six. So does the 757.
My understanding is the F-4 Corsair had that wing shape in order to keep the huge prop clear of the ground. F-4s were not allowed to land on carriers until the end of WWII, but that was not because of the prop issue.
Combination of prop clearance and landing gear strength.My understanding is the F-4 Corsair had that wing shape in order to keep the huge prop clear of the ground. F-4s were not allowed to land on carriers until the end of WWII, but that was not because of the prop issue.
On the G500/550 series we still had a differential data bus and had not graduated to fiber as yet for fly by wire at the time I was involved in the project. We had developed a Synthetic Vision System option for it.We could go on to Fly By Wire systems, and the associated aileron/roll control, and more.
On the G650ER, there are ailerons and spoilers for roll control. 2 ailerons and 6 spoilers.
8 individually controlled surfaces, the ailerons each have two distinctly different actuators, distinct wiring run in different locations and separate control for each actuator. With a total of 5 different computers
Well, cool your heels because we will be easing into more control surface details such as trimming devices in the future, but here is a prelude:Can't wait until we get to servo/anti-servo tabs!![]()
Anyone?Next wing question:
What is a Flaperon and how does it affect flight?
The word is a portmanteau of flap and aileron. It provides both roll control, and when symmetrically deployed with its counterpart on the opposite wing, lift. So, it serves as both flap and aileron.Anyone?
I suppose at higher speeds less input is wanted for a nice customer friendly ride?At higher speeds, the outboard ailerons are locked out, and roll control is provided by the inboard flaperons.
Higher velocity air over the control surfaces = more authority. More leverage. And, being at the end of the wing (a longer moment arm), it has more leverage and more control authority.I suppose at higher speeds less input is wanted for a nice customer friendly ride?
Less input is warranted because the controls become much more responsive, because of increased airspeed, but that is managed through the fly by wire system.I suppose at higher speeds less input is wanted for a nice customer friendly ride?
I can see the logic and or science in that. That is what I was understanding from the subtopic, without the proper words to convey it.Less input is warranted because the controls become much more responsive, because of increased airspeed, but that is managed through the fly by wire system.
I believe the reason that Boeing does that outboard aileron lockout (and they have done that on lots of wide bodies) has to do with torsional loads in the wing structure - moving the roll loads closer to the fuselage puts less “twist” on the wing. The load is generated where the wing is thicker/stronger.
So their required max speed is lower?In general, you are constrained by ATC holding speed limits, which have to do with protecting airspace and traffic deconfliction.
In the US, they are max 200 up to 6,0000, 230 from above 6,000 up to 14,000, and 265 above 14,000. Different countries have different limits, but in general, it’s 200 up to 6, 210 from 6 to 14 and 220 above.
The FMC will calculate a clean maneuver speed, and a recommended holding speed, which is a bit faster. That depends on things like gross weight and OAT.
If you’re able to, you would prefer to hold clean, flaps up, because that gives you the best endurance due to the lowest drag, but depending on weight, altitude assigned, and the country in which you’re flying, you may not be able to.
So, often, going into LHR, for example, we will have to hold at flaps 1 (because we are below flaps up maneuver) and sometimes at flaps 5. Increased flaps increases the drag a bit, by roughly 5-10%, but over a 20 minute hold, it’s not significant.
