Originally Posted By: Ken2
Originally Posted By: Erin
Transmission went out at 44,000 (internal seal failure)and was replaced with factory rebuilt. My warranty was extended to cover the transmission to 100,000.
If I would switch to Amsoil, Redline, or any others would this effect my warranty? Or would the dealer need to prove my choice of lubricants was the cause of the failure?
Yes, because none of these are licensed by GM. Only a fluid that meets (is licensed by GM) Dexron-VI spec will for-sure cover your warranty.
Quote:
Full-synthetic, huh? Wonder how much temp difference there would be from blend to full synthetic?
Very little.
Why on earth would you consider using an unlicensed and apparently therefore untested product, in favour of the 100 or so genuinely approved products which have gone through the correct and rigorous approval process? Obviously, that's your choice, but to me, it makes no sense.
