dbvettez06
Appreciate your input...Will talk to the tune who built the engine, research the Red Line products and report my findings...
Understatement of the year! (with all due respect) His tuner/builder, if worth anything at all, I'm sure has addressed these issues/items. BTW, Z, who was the builder/tuner?? I'm gonna take a real wild guess and say Lingenfelter, maybe??quote:
Originally posted by Oldschool:
I would suggest you think about an after market radiator, reprogrammed cooling fans, oil cooler, and a 160 thermostat. I am quite sure the temps you quote as normal will creep up very fast,even in cool weather to 220 at least especially in slow traffic if you are using OEM cooling configuation. If you use that motor for which it was built you will likely see much higher oil temps.
You mean all that engine noise, and valvetrain wear won't ruin the engine using Mobil 1? Does this engine builder perform UOA's and cry when he sees 30ppm of Fe?quote:
UPDATE.....Talked to engine builder...His thoughts where that "they use a lot of Mobil1 in their cars"... He said the fact that most guys with ultra hi performance cars, will change the oil every 3-4000 miles, Mobil1 will work great
RIGHT!! Even more so since they went inside and built the bottom end/short block with forged components to handle the stresses of high boost.quote:
Originally posted by Nick29:
If his car is supercharged and making 800hp, he threw out the warranty a long time ago.quote:
Originally posted by JohnBrowning:
I normaly am not a big supporter of following OEM recomendations. I would follow the visosity recomendations though in this application until the warranty is up. If you had to rebuild this engine out of warranty you are looking at a few thousand dollars.
I don't drive when it over 80 degrees out, hot as h#ll with black interior....Normal temps [oil] would be 195-208....quote:
Originally posted by 427Z06:
I vote for RedLine in this application. What are the maximum oil temps you see?
Will answer some questions..Thermastat was changed to a 170, coolant will run at 176 on a 80 degree day...Oil cooler yes, reprogrammed fans are also engauged..The stock rad had done an excellent job with keeping coolant in check, GM did a great job with the stock Z....I had thought there would be issues, but am very pleased with the results!quote:
Yeah, sorry, you do make some good points/arguements there!quote:
dailydriver--understatement of the year???? -with all due respect?? Hmm! The individual asking the question and making responses to clarification questions suggests by the content of the statements that he may not have the experience with this GM variant or the stesses "force feed" motors are placed under, or at least the communication with the builder is minimal. I doubt that if Lingenfelter was the builder that there would have been any question about what oil to use or a discussion of the various M-1 flavors several of which should not even entire the discussion considering the engine inquestion. But that is just my opinion.
Yes, all of us LSxx fans/owners want.need to know!quote:
Originally posted by Patman:
Is your Z06 a C5 or C6 by the way?
It is an 01Z06....Other than re-placing a clutch, which the dealer screwed up and later refunded me the entire cost, not one issue!!quote:
Quite right! I do hope he has some of those super heavy duty 300M alloy half shafts, as well as an upgraded ring & pinion/center section. I've seen those things twisted like barber shop poles (or snappedquote:
dbvettez06--Also wheel-hop is an issue particularly with 01s--this can destroy your rear real fast.
^^^ this is howquote:
Originally posted by dbvettez06:
the engine is super charged, stroked/forged etc...
