Mobil1 10w-30 - 4000 miles - 2005 Subaru WRX 2.0L Turbo
Sunnyvale, CA
Good results with this oil. Used the Subaru OEM filter (Tokyo Roki - 15208AA100).
Onto the nitty gritty:
I drive the car moderately. I ALWAYS let her warm-up. ~3k RPM shifts when the she's cold and ~4k RPM shifts when she's warm. The car see's redline more than enough
Car averages two 7-mile city trips on weekdays and 30-50 mile highway trips on the weekends.
I'm trying out GC (German Castrol) now, so we'll see how it goes.
code:
EQUIPMENT MAKE: Subaru OIL USE INTERVAL: 4,000 Miles
EQUIPMENT MODEL: 2.0L Turbo OIL TYPE & GRADE: Mobil 1 10W/30 (Gas)
FUEL TYPE: Gasoline (Unleaded) MAKE-UP OIL ADDED: 0.5 qts
These 2.0L Subarus are nice wearing types and yours is not the exception. Universal
averages show typical wear metals for an oil from this type engine after about 4,745 miles run on the
oil. Your oil was in use just short of those miles, and we found wear generally at better than average
levels and in the correct balance to show normal mechanical parts. Air and oil filtration appear normal.
This was 10W/30 engine oil with no gas moisture or anti-freeze in it. The TBN for this oil was 4.7, still
plenty high. Try 5,000 miles for the next sample. Wear will stay normal.
ELEMENTS IN PARTS PER MILLION (PPM)
MI/HR ON OIL 4,000 Universal Averages
MI/HR ON UNIT 15,000
SAMPLE DATE 04/08/06
ALUMINIUM 2 3
CHROMIUM 1 1
IRON 4 8
COPPER 7 4
LEAD 2 5
TIN 0 1
MOLYBDENUM 67 79
NICKEL 0 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 35 85
SILICON 9 8
SODIUM 4 6
CALCIUM 2171 2486
MAGNESIUM 11 114
PHOSPHORUS 601 745
ZINC 713 888
BARIUM 0 0
cST SUS VISCOSITY cST SUS FLASHPOINT FUEL% ANTIFREEZE% WATER% INSOLUBLES%
VISCOSITY VISCOSITY INDEX VISCOSITY VISCOSITY IN ºF
@ 40 ºC @ 100 ºF @ 100 ºC @ 210 ºF
VALUES 59-68 >365
SHOULD BE
TESTED 61.4 370
VALUES WERE
Looks great. You don't even have the slight iron elevation that M1 sometimes allows. GC will probably do fine, but I wouldn't worry about it. The easy-to-find stuff looks like it will do just fine the way you use it.
I used the standard M1.
The only thing I'm slightly concerned about is the Flash Point. It's still above the recommended value. At this point, I'm not even sure "what" the flash point tells me. I'll have to do more searching...
The first post looks fine in Firefox, but not for Internet Explorer. Here's a re-formatted version for IE users:
code:
ALUMINIUM 2 3
CHROMIUM 1 1
IRON 4 8
COPPER 7 4
LEAD 2 5
TIN 0 1
MOLYBDENUM 67 79
NICKEL 0 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 35 85
SILICON 9 8
SODIUM 4 6
CALCIUM 2171 2486
MAGNESIUM 11 114
PHOSPHORUS 601 745
ZINC 713 888
BARIUM 0 0
VALUES 59-68 >365
SHOULD BE
TESTED 61.4 370
VALUES WERE
No cause for concern. Acceptable value should be 365 or higher.
quote:
Yep, those are typical WRX flashpoint values IIRC.
-Dennis
