Yes, he (
@Doug Hillary ) is a wealth of knowledge on UOA's, likely having more experience with them than everyone else on here combined. Very much an SME on the topic.
I'm not personally alarmed by the OP's #'s, given the track use. I'd like to see a few similar runs without that usage profile to see if the numbers are tracking up or down.
Also, perhaps worth mentioning, if you look at his 370,000 run, silicon jumped, along with a bump in copper and the appearance of lead. This may indicate dirt ingestion (perhaps a poorly fitting air filter, or some other intake tract leak) which resulted in a small particle streak in a bearing (which isn't uncommon). If those continue to trend down, that's typically what that points to.
