There’s always one out there…then others follow, lol.0W16 in an '07? That's an interesting twist..
But the report is good, so can't argue with the results.
How can we make that ?Can he can, I guess.
I vote he goes thinner. Let’s try 0w8. I’ll sponsor the Lube purchase.
Not me. Not on your life. He needs to run a thick oil, or he'll wear that engine out. Thin oils are only for fuel economy. They can't possibly protect an engine from wear. I'm sticking with nice, thick 0w20!Why 0w 16 ?
The oil is likely close to a monograde, being almost entirely PAO-based:The report is OK but............ Oil's too thin. The starting vis for 0-16 AFE is 7.2 and the exit vis after 6800 miles is 7.15? Can't be. Looks like the oil vis thinned and is on it's way back up + it used 12 oz. I'd run 0-20 AFE next time. JMO
That wasn't a long run. But with that much PAO, it actually might do fine as a long run oil. Plus, the TBN looked good.I defer to your expertise, but, the oil had to have sheared more than .05 in 6800 miles. AFE is not a long run oil.
I keep getting told on here that TBN is worthless now.Plus, the TBN looked good.
Who said it is worthless?I keep getting told on here that TBN is worthless now.![]()
You keep following me around implying that everytime I mention it.Who said it is worthless?
For one thing it’s a Blackstone report. There is no reliable way to tell if a viscosity deviation is due to mechanical shear or fuel dilution. More so, Blackstone has also shown they cannot reliably measure viscosity so you’ve got two issues with ascribing something on that report to any one problem. As Overkill noted, there is very little VII in that oil and it’s these molecules that exhibit shear not the oil. Oil molecules do not shear.I defer to your expertise, but, the oil had to have sheared more than .05 in 6800 miles. AFE is not a long run oil.
