Sorry, that got cropped off.... VW Golf Sportwagen TDI with about 60,000 miles. DPF is a non issue. To get the oil from my crankcase, I used medical grade plastic tubing which is fairly soft and it may have explained the high levels of silicon as the oil temperature was probably around 180F.It would be even more interesting if we knew what vehicle (year, make, model, engine ...)
Even if you had a DPF, the 1% ash is nothing to write home about. T6 has the same and been running a non-neut Cayenne D with it since day 1.Sorry, that got cropped off.... VW Golf Sportwagen TDI with about 60,000 miles. DPF is a non issue. To get the oil from my crankcase, I used medical grade plastic tubing which is fairly soft and it may have explained the high levels as the oil temperature was probably around 180F.
No. Second.Was this the first fill of Extreme? Could have residual from a previous as your numbers are 30 weight previously
I'll update the thread title with that info.Sorry, that got cropped off.... VW Golf Sportwagen TDI with about 60,000 miles. DPF is a non issue. To get the oil from my crankcase, I used medical grade plastic tubing which is fairly soft and it may have explained the high levels of silicon as the oil temperature was probably around 180F.
Full delete. Malone 2. Stock turbo. Nothing else. Straight pipe. Drive like a nursing home bus driver. RARELY do I stomp on the accelerator. Wondered about that whole shear and bore scoring phenomenon too but then I look at the wear metals and it's pretty good.What’s up with your motor? I see you mentioned no DPF, so you must have tuned it out. You’re shearing that oil far quicker than most have. Any mods or other ancillaries? I would worry a bit as to why… How much are you evacuating out of the sump?
