- Joined
- Sep 28, 2002
- Messages
- 39,799
Does it have an oil temp gauge? I believe that most Audi engines have a heat exchanger that would tend to make the oil gravitate to 100C/212F in a relatively short time (10 miles maybe).
If that's the case and you have one of these exchangers, keep in mind that after either so many miles ..or so many minutes of operation, you'll be at whatever visc that the oil is spec'd at. You won't be operating at 160-180F with a 30 weight in the winter (if you call what you have "winter"). So unless you have some startup issue (unlikely) I wouldn't necessarily think that switching to a lower visc in anything other than the most severely cold environment would be advised.
I usually offer exactly the opposite advice to short trippers without heat exchangers. They can usually go down a grade ..since they never warm the oil enough to have it reach its spec'd visc. Admittedly, short trip isn't the same (automatically) as "city".
