Mobil 3324 ATF: where to buy?
In the shop
Hello again folks. I just spoke with a Mobil technician that said their recommendation for my 2009 Toyota Camry atf is Mobil 3324 ATF
Anyone here know a place to purchase this?
Thank You in advance
I don't know where to buy it.
I needed Mobil 3309 for a ford 500 6sp auto, the easiest and cheapest place to find it was to get Toyota t-IV from the dealer. I know Toyota WS is more expensive but may be an easy, cost effective solution overall.
Sorry, I thought this was the other spec.
3324 is the same as Toyota WS.
Maxlife ATF is an excellent replacement, and is the same lighter viscosity.
I'll check my Autozone for Maxlife. My Wal Marts just have ST low Vis stuff
Adam, how did you contact them?
I'd like to know what they say should be used for my Mercon-V Ford.
Good sir: I went to the Mobil site and to "contact us" and wrote them a quick question. I believe member TIG1 uses their Mobil 1 "multi vehicle ATF" in both his Fusion and Focus. Hopefully he will check this talk out
I have used Mobil 1 ATF in my Fords since 1990 with no trans or PS pump failures. YET! My Fusion calls for FNR 5 fluid, but I have used M1 in it from the start. Shifts great.
Originally Posted By: dlundblad
I wonder if Valvoline's MVI would have been a good choice too?
That Valvoline import multi (as well as Castrol's) is not the newer low-viscosity type like 3324/WS is, so probably not.
