Mobil 1 Synthetic ATF
Maryland
Hello, I have a few quarts of Mobil 1 Synthetic ATF and would like to know if it's safe to use in my 2004 Infiniti G35X transfer case? The transfer case calls for matic D transmission fluid...Thanks
My 2004 Altima auto transmission requiring Matic-D loved Mobil 1 ATF.
As did any of my auto transmissions that Mobil 1 ATF was suitable for.
There are folks who will predict gloom and doom over using this. Some even argue that you can't even substitute Matic-J, K, S, etc either - it must be Matic-D and Matic-D only.
I used Mobil Synthetic ATF+4 in my dad's van for a couple of changes and it's much better shift quality than the Mopar brand fluid. I know this is different from what you intend to use but in terms of Mobil knowing their stuff and making high quality transmissions fluids I would say they are a top-shelf fluid for sure. Use it with confidence.
In my view, any fluid meeting the specs is better than Nissan OEM fluids.
I have owned three Nissans so far never found the OEM fluid to hold up.
Any time I get a new or used Nissan I change out the factory or dealer fill.
How is this possible with ATF+4 is the same across all brands?
I'm of the opinion that there's nothing magical about Nissan or most OEM's fluids. I don't believe that Mobil 1, Castrol, Valvoline, etc would say one of their fluids is okay to use in a vehicle if it really wasn't. I mean, most of them make multiple fluids for this reason - they know where it works and where it doesn't.
I have no proof and it's just speculation, but I think plenty of OEM fluids are just re-labeled off-the-shelf fluids. I can see an automaker spec'ing a fluid that needs A, B, C characteristics and soliciting "bids" from the oil/fluid manufacturers. Plenty of them may come back and say (using Castrol as a simple example), "our Transmax Import Multi-Vehicle meets all of your specs and exceeds some of them". Valvoline could say the same and so on with others.
I am about to put the same Mobil 1 ATF in my FX45 transfer case (essentially similar to G35x). I've heard not to use Dex VI, as it could cause some other issues - like shuddering. Our T-Cases have electrically actuated clutch-packs in addition to the chain. Traditional T-cases have gears and a chain and less frequently a clutch pack. I think I used Mobil 1 ATF last time. Mobil 1 ATF says it is not recommended for Dex VI applications, and it is (was) recommended for Dex III and Matic D/K/J, so it seems like they are almost matching what Nissan says, which is Dex III in the case and Matic J or S in the transmission aside from the J overlap - which may have been a mineral oil? Whatever I put in last time has lasted 60K w/o issue - hopefully this time it is the same.
I'm not up to speed on all the technical specs, but this seems like a reasonable use for this oil.
It's not the same across all brands. Officially licensed ATF+4 fluids use a specific basestock but the additive package can vary doesn't have to be Lubrizol as I understand it. On unofficially licensed fluids they can use PAO such as Amsoil which by the way their multi-vehicle ATF that covers many specs works superbly in ATF+4 applications especially in the winter. It was the best fluid I used in my Journey next to the Mobil 1 ATF in my dad's Caravan. My dad is not on Amsoil / M1 50% mix as of the last change.
