The problem, if it is a problem, is gasket size. Otherwise you can get any length and diameter you want from Mobil 1 filters.
Just go to Wix and plug in M1100 - 110 M1200-210 M1300-310 and you can see the 3/4-16 thread filters. The gaskets are typically bigger by a click or two.
