Mobil 1 or rotella t6
ny
anyone got opinions which is better rotella t6 5w-40 or Mobil 1 5w-40 diesel. walmart here has the Mobil 1 on sale for only $15 wondering if its as good as the rotella t6?
How about telling us what car/engine this is for, what's your driving pattern, planned OCI, etc.?
But all in all, I'd expect Mobil 1 5w-40 to be at least as good as T6.
Neither is head and shoulders better than the other.
I find the thick visco of Mobil 1 5w40 in the winter to be less than ideal, while T6 should provide better cold flow.
If I recall correctly, T6 is a 5W-40. Is the brand-to-brand difference in viscosity/flow between different 5W-rated oils when cold really noteworthy?
Depends on how much of a difference we're talking about.
Here's visco for Mobil 1 5w40
0C : 566
10C: 351
20C: 224
30C: 148
40C: 100
50C: 69
60C: 49
70C: 36
80C: 26
90C: 20
100C: 15
And for T6
0C: 454
10C: 287
20C: 188
30C: 126
40C: 87
50C: 61
60C: 44
70C: 33
80C: 24
90C: 19
100C:14
so since the Mobil 1 is on sale for 5 dollars cheaper basically i should get that because even if the t6 is better the Mobil 1 is a very close second would that be fair to say?
If Mobil 1 5w40 is on sale and is cheaper, get it. You cant make a bad decision. Get the one that is cheaper. Mobil 1 is a little thicker than the T6 if it matters too you. I personally would not say one is any better or worse than the other. Both are top notch.
That's how I take it. I'd go with the Mobil 1 if it was $15.
is thicker bad since i get some cold winters here? its about 10 degrees right now we get down to about -1
