Mobil 1 HM 5w30, 7000 miles, 2005 Chevy Malibu 3.5
Originally Posted By: ABerns
As you may have noticed, on the previous UOA the board (and therefore me :)) assumed Blackstone simply made a mistake with the TBN calculation. Now, who knows?
I don't think they did, given how low it was with this oil too. I think there's an issue that is causing rapid TBN depletion.
Originally Posted By: skyship
The UA for Sodium is 38 ppm, so does anyone know how much is in the Valvoline, because I have not seen an oil with more than about 100 ppm before.
I don't think you looked too hard....
From this thread
Originally Posted By: Loobed
Here is a list of additive ppm for Valvoline oils.
This was taken from their product data sheet.
Effective 12-15-2010
TBN and Calcium is higher in Max Life; which also has moly.
No other type has Moly, not even the racing oil.
Synpower 5w-40 HST has the highest amount of Calcium.
VALVOLINE PREMIUM CONVENTIONAL MOTOR OIL
SAE 5W-20; SAE 5W-30; SAE 10W-30; SAE 10W-40;
SAE 20W-50; SAE 30; SAE 40; SAE 50
Zinc 830
Phosphorus 760
Calcium 1670
Sodium 490
TBN 7.3
VALVOLINE NextGen™ CONVENTIONAL MOTOR OIL
Zinc 830
Phosphorus 760
Calcium 1670
Sodium 490
TBN 7.3
VALVOLINE MaxLife™ Motor Oil
SAE 5W-20; SAE 5W-30; SAE 10W-30; SAE 10W-40; SAE 20W-50; SAE 30
Zinc 830
Phosphorus 760
Calcium 2110
Moly 140
Sodium 490
TBN 8.7
VALVOLINE NextGen MaxLife™ Motor Oil
Zinc 830
Phosphorus 760
Calcium 2110
Moly 140
Sodium 490
TBN 8.7
VALVOLINE SYNPOWER MOTOR OIL: ILSAC Grades
0W-20; 5W-20; 5W-30; 10W-30
Zinc 830
Phosphorus 760
Calcium 2110
Sodium 490
TBN 8.7
VALVOLINE SYNPOWER MOTOR OIL: non-ILSAC Grades
5W-30 MST; 5W-40 MST; 5W-40 HST; 20W-50
Zinc 840 (5w-40 has 990)
Phosphorus 770 (5w-40 has 900)
Calcium 1930 (5w-40 has 3260)
Sodium (none listed)
TBN 7.0
VALVOLINE VR-1 RACING MOTOR OIL
20W-50; 10w-30; SAE 30; SAE 40; SAE 50
Zinc 1400
Phosphorus 1300
Calcium 2100
Sodium 490
TBN 8.5
No Data for VALVOLINE VR-1 RACING (SYNTHETIC) MOTOR OIL
10w-30; 20w-50
Castrol is the other big user of Na. I believe it's in Mobil conventional too.
I don't know, my UOA on Petro-Canada was only 3500 miles and came back with a TBN of only 1.5. I think maybe it is just a result of an engine that's a bit hard on oil and a small sump.
You have the same engine? If so, guess we know what engine certainly is NOT a candidate for extended drains eh? LOL!
I recently did about 7K miles on M1 0w-40. I still had a TBN of 7, LOL!
As far as I know the '05 Malibu and '06 G6 are both the LX9.
To your point about the M1 0w40, I have 3 runs on the blend ranging from 5300 - 6600 miles that had TBN of 4.5-6. That's with only 40% M1!
As a side note, I'm considering running straight 0w40 this year in both cars when I change them in the spring. Just to see what I get.
I had been so focused on our discussions about the high iron that I forgot to ask - what do you think about the Lubricheck results for this oil (Lubricheck showed 8/10)?
I'd recommend PYB for short 3k run like others have mentioned. How long time wise is the oci? Does the car see a lot of idling? Esp in the morning warming up.
I would like to see more comparisons. I'm kind of surprised you wouldn't get a 10 or a warn on this one though. Based solely on the TBN though it looks about right if you want to change at 8 or 9. What is their recommendation for a change?
I received a Lubricheck for xmas and it does seem to be accurate with where I believe they are. I am using it to to check my cars about every 1000 miles to extend oil changes.
