Mobil 1 Extended Performance 0w20 or TGMO 0w20....
FL, USA
Right now I can get Mobil 1 Extended Performance 0w20 for $23 on Amazon, I have 5 quarts of TGMO 0w20 that I was planning on using. I was thinking since the M1 is on sale and I could get it at a decent price that I could run it for the summer fill as it has a high percentage of PAO and might stand up to the summer heat better, then I could use the TGMO for the fall/winter fill. Is this a good idea or would you just stick with the TGMO that I already have in stock. OCI would be 5,000 miles or MM which would work out to about 7 months. Driving style is severe, most trips being 1-5 miles in length. What would you do? Thanks in advance BITOG!
Great price for the Mobil 1 Extended Performance. I saw it on Amazon for $26.68 [5 qt jug] shipped free, as part of an order over $35.
Is your price a special deal? Thanks.
Originally Posted By: car51
Since you have TGMO, why not use it?
I just thought that since the EP was on sale, I would buy some, and if I had both at my disposal, the EP might be a better suit for the warmer months.
I don't think it'll matter much for warmer months since your car doesn't warm up much. Now if you were driving it real hard and some 80 mph highway I'd maybe choose a more suitable summer oil.
Originally Posted By: Nate1979
Did you already get the M1 rebate?
No I have not, Is Amazon included?
Yes, check the long thread in the promotions section.
Thanks for reminding me! I had forgot about the rebate. I just purchased a 5 quart jug of the Mobil 1 Extended Performance 0w20. I got it for $23 (after using $3.?? in rewards points I had accrued), the rebate should be $12 so after its all said and done I will be getting a jug of Mobil 1 Extended Performance 0w20 for $11 and some change. Sounds like a steal to me! The TGMO I had waiting to go in will be used for the late fall/winter fill.
Originally Posted By: Nick1994
?.................. now if you were driving it real hard and some 80 mph highway I'd maybe choose a more suitable summer oil.
Most people who have posted about TGMO seem to rave about how good it is.
I did not realize that TGMO doesn't handle the heat well.
It ought to handle the heat just fine. I just figured between the two oils, the one with more PAO would be the better suit for the summer. Both oils are top notch, the Mobil 1 Extended Performance 0w20 is just the top of the top.
Edit: plus the Mobil 1 Extended Performance 0w20 has an HTHS of 2.7 vs the TGMO 0w20 of 2.6, yes this is splitting hairs but its just what we do here on BITOG.
I thought poa helped the cold flow properties and thus would be better in those frigid Florida winter months.
Mobil 1 Extended Performance is good for 15,000 miles while TGMO is good for 10,000 miles.
thus I'm going to use Mobil 1 Extended Performance in my prius for full 15,000 or maybe even 20,000 miles.
for you, with short tripping, no need to use synthetic oils.
Cute....the reason I would use the TGMO is its crazy VI, I was thinking the low start up viscosity would be better.
The difference isn't really all that much. The M1 product is 60-70% PAO, the TGMO is 0% PAO. If you get the M1 at a good price, that makes it a better "deal" (because PAO is expensive). It would also have significantly less VII in it as you can make a 0w-20 with PAO with no VII's whatsoever....
IMHO, the EP 0w-20 is a better oil. But I don't worship at the alter of VI so YMMV.
Overkill, would you please explain the comment that TGMO has 0% PAO. First I have heard of it.
Thanks!
Still a NOOB here on oil. I also use TGMO in the Camry.
