Regarding 'being back'... Yes, and create a lightstorm with my first post!! Yes, great to be back!
George
George
This is totally bogus. I've been looking at Mobil MSDS's for over two years and they have NEVER given a breakdown of the base oil blend. The only chemical breakdown they give is of the additives. For the base oil, the Mobil 1 MSDS has always simply said "synthetic hydrocarbons" as it does now. (Go to the Mobil 1 web site and take a look.) Take a look at the Delvac 1 MSDS. It doesn't say anything about esters either (and it never has), but does anyone SERIOUSLY doubt that Delvac 1 has esters in it?quote:
Originally posted by GeorgeCLS:
However, it is not rocket science: the MSDS for old formulation Mobil 1 indicated >10% ester. New formulation Mobil 1: no ester component is mentioned....
I don't believe this and I won't belive this until I see documented proof from ExxonMobil.quote:
The esters in Mobil 1 are "no more".. One of the evolutionary changes was the elimination of the ester portion of the formulation (needed for additive solubility, natural detergency, seal swell). Thus Mobil 1 is essentially all PAO now, enabled through the magic of chemistry; even superior performance without the negative aspects of the ester.
George Morrison, STLE CLS
If George says it's true that's proof enough for me. He's the next best thing to having ExxonMobil documentation.quote:
Patman, to say that Mobil 1 now has NO esters is simply too outrageous to be credible. It flies in the face of everything we've come to know about modern synthetic PCMO formulations. It also goes against many posts by MolaKule, who has stated many times that one of the primary elements in the SuperSyn formulation is new esters developed by ExxonMobil chemists.quote:
I understand what you're saying, but I just can't see George saying something like this unless he was sure it was true. Don't forget, he's got some very impressive credentials, and he's definitely got some insider info from Mobil too.quote:
Well, I'd like to see his credentials. This is not the first time he's posted something that is, IMO, questionable. Remember this little tidbit:quote:
Once I read that post by him, I began to take just about anything he'd post with a grain of salt.quote:
If you are using Mobil 1 products, the 0W-30, 5W-30 and 10W-30 are essentially the same..
Basically 30 weight base stock that just happens to pour at 60 below zero..
One might say the only difference between the 3 Mobil 1 oils is the label that is on the bottle....
quote:
The Mobil Tech support site (800-662-4525) is staffed by lubrication engineers, most of whom have many years experience both field and product development, some involved in the devopment of the Mobil 1',s SHC series, etc.. You will not find a more knowledgeable bunch of lube engineers, IMHO.. All are STLE CLS..
George
The addition of ExxonMobil's SuperSyn high viscosity PAO to the base oil blend would account for it as well. That doesn't mean there are no esters in it. The pour point of the SL/CI-4 Delvac 1 is quite a bit higher than the SJ/CH-4 formulation. Should we therefore conclude that Delvac 1 no longer has esters in it?quote:
Originally posted by TooSlick:
It would explain the higher pour points of the supersyn formulations for one thing, vs the trisynthetic formula.
Can someone explain how an "esterless" oil relates to quality of the oil? Does this make Mobil 1 a better product then oil with esters or is it just more cost efficient for ExxonMobil to make it this way. As TS mentioned above, this seems like this is just a new approach yielding the same result with less chemistry. (Did I answer my own question?) With ExxonMobil being as large as they are and having probably the best of the best of chemists, I don't doubt they pulled it off. Take a look at this companies financial statements....quote:
What is important here is achieving the best mixture of physical/chemical properties in the fully formulated lubricant. How you achieve this is open to a wide range of possibilities.
