Mobil 1 ESP possibly using diblock polymer
Good comments ! … 0W30 ESP may have slightly better cleaning ability while the 5W30 ESP may produce less intake valve deposits (important for GDI) . Then again , Euro specs may cloud the issue a bit as both oils should be top performers … So , what exactly are the pro’s & con’s to both oils ?
Can you please elaborate on this?
I’d say no one has any evidence other than speculation, to be honest. Even the thoughts about valve deposits.
Unless you’re burning an extremely high amount of oil it wouldn’t be an issue. At excessive burn rates it could damage the catalytic converter
you mean that if you burn plenty of oil which has more zinc and phosphorous could damage the cat?
why is that?
so i guess in this case of an oil with low saps is better for cat?
why is that?
If burning high amounts of oil a low saps oil would be better for the catalytic converter.
And it’s to do with Saps levels. Them burning and going to the catalytic converter both clogs and decreases efficiency causing it to die sooner.
The wider temp range 0W30 oils use more VII’s while 5W30 oils use less VII’s . The VII’s are thought to produce more intake valve deposits in GDI engines . Conversely , as VII’s improve this may no longer be the concern it once was . I say if an oil meets the MB & VW deposit specs - then it has to be well engineered and use with confidence.
i burn oil so i need low saps.
but i also have fuel dilution ,well its less now, but it is there.and in another topic , cant remember which one,some members suggested that for fuel dilution its better a high saps oil for retaining more additives .
so burn oil ,mid saps ( i never buy low saps )
fuel dilution high saps
solution?
That is if all things are equal. They are not.
These two oils have two different base stocks. If you compare older ESP 5W30, I would agree. New one? I am not so sure.
solution?
No you don’t need low-SAPS. Primary “killer “ of catalytic converter is Zinc. Just because it is low-SAPS, doesn’t mean it has lowZinc levels. ESP Zinc levels are around 900ppm.
Is that good, bad, or “meh” in a modern GDI engine?
It does not have anything to do with GDI. Zinc is not one that sticks on valves. For anything higher, ZDDP reduces the possibility of LSPI. Euro oils were always high in ZDDP and very, very few EUro engines have LSPI issues. We have discussed a lot that. The LSPI issues started also when API reduced phosphorous levels with API SM for 0/5W30 oils. Euro oils stayed with high phosphorous/zinc levels, that is why many are still labeled API SL.
Doh!
I mis-typed.
I was thinking in terms of the Cat, not DI.
I don't recall any real consensus on the IVD issues.
I remember some saying an oil that burns more (or has a higher Noack #) is better for the IVD. Because it evaporates "better" and doesn't leave as much deposits ... Basically, a very low Noack # (I assume) wasn't good or something to that effect.
Also that the cause (or the main cause?) of IVD is not from the PCV end but mainly from the the oil getting thru into the combustion chamber.
Not sure if any of the above arguments were or remain valid or somewhat valid but all we want is peace in the world :alien: sorry, I meant to say which oil and/or approvals are better for the IVD?
That might be a million-dollar question. 👈
Very low Noack is good.
Difference in IVD is how much of sulfated ash each oil produces.
That’s one thing that disappointed me when M1 changed from ESP Formula 5w30 to simply calling it ESP 5w30. The older version had 0.6% SA and the newer version has 0.8%. One of the big reasons I chose ESP Formula for my Corvette back in 2018 was that low SA, which I figured was perfect for keeping IVD low. At least for most of my oil changes all these years I have been using the original older formula. I stocked up quite a bit when they changed the formula.
Not only that, ESP Formula had Noack value of 5.6%.
