Originally Posted By: blackman777
I see this a lot on this forum but don't understand it. Why swap fluids if the one you're already-using (Redline D4) is working so fantastically. I always pick on fluid and then stick with it. "If it ain't broke, don't fix it." That's why I'm wasting so much time researching VW oil. I will pick the best one for my new beetle, and then run it for the next 300,000 miles without alteration.
Because Red Line cracked down on their pricing so I can't get it from the place I normally use as nearly as cheap as I used to while I can get Amsoil at PC pricing. I'm equally confident in both products.
Quote:
As for the Redline C+, when I went to the allpar forums and told them I had used it, they immediately said that was a gigantic mistake. When I said the seals started leaking, they said that's what happens to every person that uses a non-Moper ATF. Switching back to Chryslers +4 fluid fixed the problem, but did not undo the damage to the torque converter (which my dealer said needs replaced). So the car was basically went from perfect running to undriveable thanks to my little Redline C+ experiment.
What seals started leaking?
