quote:
Thank you for your inquiry,
The new formulation of Mobil 1 ATF is already in the market at retail stores however, it will be mixed on retail shelves due to the back supply that retailers have in stock. This is the reason why I have stated to make sure the label reflects that the product meets the Ford MerconV requirement. The product that states Mobil Multi-Vehicle ATF is a synthetic blend that meets the GM DexronIII, DexronIII-H specification, Mercon, MerconV, Chrysler ATF+3 and ATF+4, the new Mobil 1 ATF will meet the same exact requirements as well. Mobil 1 ATF and Mobil Multi-Vehicle ATF are two different products (meets the same requirements but, Mobil 1 ATF is a full synthetic and Mobil Multi-Vehicle ATF is a synthetic blend). Neither one of these products stated above will meet the Honda ATF Z-1 requirement (dealer product). You can perform a normal transmission fluid change, what is left in the torque converter will mix just fine. You can perform a complete transmission flush if you would like which will ensure 100% of the Mobil product being in your transmission. The GM Dexron VI requirement is only used on 2006 models and Mobil will produce and market a product will demand constitutes such an action.
-Matt
