- Joined
- Jul 15, 2023
- Messages
- 1,667
I agree. My point was not that used oil analysis can discern details on any differences, but rather that differences unto themselves are evidence of something (it doesn’t matter what). Given how complex engines are, it is very unlikely that any two used oil analysis will always be the same when varying only oil type.used oil analysis lack the resolution to allow you to discern meaningful differences in wear performance between different oils, that's not their intended purpose, but unfortunately, believing they can results in many people chasing their tail.
Engines are complex mechanical devices with various systems in them that can indeed respond differently to different base oil blends, additive combinations, FM formulations...etc. This can result in subtle differences that may, or may not, be apparent to the end user. This could be something as simple as increased/reduced volume of consumption due to the PCV setup, or an apparent reduction/increase in NVH due to the FM interaction with something like cylinder deactivation. However, used oil analysis aren't going to give you any insight into this, nor does it mean wear performance is going to be any better/worse.
Personal anecdote: Years ago, I had very high levels of consumption with AMSOIL AZO 0w30 in my Expedition 5.4L. Mobil 1 0w30 didn't consume at all in the same vehicle, nor did Motul 0W-30. I did several OCI's to see if the consumption tapered off (which it can with a chemistry change), but it never did, so I had to stop using that oil in that vehicle. Do I know why that oil consumed? No. Do I know HOW that oil consumed? Also no. Had I done used oil analysis on that oil, would it have given me valuable insight into this phenomenon? absolutely not.
Had you done used oil analysis, while it may not have given you insight, it could have shown a difference in fuel dilution, rate of degradation, etc. Any difference there is evidence that the complex system that is the engine has variables within it that respond to the input variable. It’s like “black box” testing.
