After all the to-do about Mobil 1 formulations, etc. etc. I decided to do another analysis of my oil (haven't done an analysis of M1 for a number of years, since they've always been very good even at extended drain intervals in my experience). This truck has 90k miles on it now, and has had M1 since around 10k miles. Typical oci has always been 12k-13k miles. I do NOT change filters mid-change. As typical for this engine, this oil has had no makeup oil, and it was down maybe 1/2 qt at the time of the change. Air filters are changed every 10k miles - a new air filter was installed approx 3k miles into this oil, and it was almost time to change it again when the oil was changed out.
Blackstone analysis of (regular) Mobil 1 5W30 after 12,500 miles in 4.0 sohc Ranger.
Aluminum 15
Chromium 4
Iron 44
Copper 12
Lead 0
Tin 2
Molybdenum 88
Nickel 1
Manganese 1
Silver 0
Titanium 0
Potassium 1
Boron 53
Silicon 14
Sodium 22
Calcium 2424
Magnesium 16
Phosphorus 650
Zinc 798
Barium 0
TBN 3.4
SUS visc 59.2
Flashpt 400
Fuel < 0.5
Antifreeze 0
Water 0
Insolubles 0.3
Blackstone comments:
Al, Ch, Cu were all out of line in the sample. Universal averages show typical wear from this type of engine after about 4800 miles use on the oil. This oil was run longer, so we expected to see iron read high, though the other metals should have all read lower. Iron is the only metal that should increase when an oil is run longer, so we think 12,500 miles may have been too long for this engine. The TBN was okay at 3.4, so the oil has some active additive left. Try dropping back to a 10,000 mile oil use to see if wear improves.
Any other comments?
Aluminum 15
Chromium 4
Iron 44
Copper 12
Lead 0
Tin 2
Molybdenum 88
Nickel 1
Manganese 1
Silver 0
Titanium 0
Potassium 1
Boron 53
Silicon 14
Sodium 22
Calcium 2424
Magnesium 16
Phosphorus 650
Zinc 798
Barium 0
TBN 3.4
SUS visc 59.2
Flashpt 400
Fuel < 0.5
Antifreeze 0
Water 0
Insolubles 0.3
Any other comments?
