If price was the same as well as availability...which is "better"? I was set on the XL but I realized the price of each is literally within a few cents/qt of each other and I can pick up either less than 10 minutes from my house. I believe the XL is mainly group III and the Mobil 1 is mainly PAO so the nod would seem to go to the Mobil 1 in that respect but it seems like the XL is a better formulation (just a guess based on UOA's).
The car is a 2004 Grand Prix, supercharged and slightly modified to provide 12 psi boost and 300hp, 180 thermostat, 80% short-trips. OCIs will be every 8000 miles/9 months with a Pure One filter. Car is driven hard a couple of times a day and it sees near redline for a couple of seconds at a time. Ambient temperature is normally between 0 and 100.
The Mobil 1 is thicker at 40c (64.8 vs 58.2) and at 100c (11.3 vs 10.5) but has no spec for -30c so I'll assume it is also thicker there. I'm really looking for a very thin 5W-30 but I'm not sure that there will be that much difference between the two. I thought Mobil 1 was known for being a thin 5W-30...
Does the performance of Mobil 1 outweigh the (very) slight cost difference and the slight increase in thickness over the XL? If this were not a performance car I would just go with the XL, but will the Mobil 1 protect better due to the boost level?
