Originally Posted By: BusyLittleShop
Originally Posted By: LoneRanger
You can't use the Mobil 1 5w30 and Mobil 1 10w30 car oils in a wet clutch bike, they're marked "energy conserving" and contain friction modifiers that will contaminate the clutch plates and cause slippage.
Negative... Friction Modifiers are wet clutch compatible... friction modifiers have been
used many years by the lubricant industry. Many products made use of friction modifiers:
- Automatic Transmission Fluids (ATF's or those designed for smooth clutch engagement)
- Limited Slip Gear Oils for limited slip differentials and transaxles
- Multipurpose tractor fluids for wet brakes
- engine oils
Friction modification films consist of orderly, close-packed arrays of
multimolecular "whiskers," loosely adhering to each other. The outer
layers are sheared-off easily, allowing for low coefficient of friction.
Of course this is not true. Put the wrong ATF package in an automatic transmission and you can run into some serious problems with clutch slipping. Back in the day people had slipping issues when they accidentally put Dexron ATF in Ford Transmission that needed Type F. Many C6's were shelled in relatively short order by the improper use of the more highly friction modified Dexron.
- engine oils
