Here is my oil analysis from Blackstone
EQUIPMENT MAKE: TOYOTA
EQUIPMENT MODEL: 4.7L V-8 (2UZ-FE)
FUEL TYPE:GASOLINE (UNLEADED)
OIL USE INTERVAL: 10,391 MILES
OIL TYPE AND GRADE: MOBIL 1 10W-30 (GAS)
MAKE-UP OIL ADDED: 0 QTS
THE PUROLATOR FILTER DID A GOOD JOB FOR YOU, AS YOU CAN SEE IN THE LOW INSOLUBLES LEVEL. THAT AREA IS FINE. BUT WEAR WAS HIGH FROM THE LONG OIL CHANGE. WE CAN'T SAY FOR SURE THAT YOUR TOYOTA ENGING DOESN'T HAVE A PROBLEM -- WE CAN'T TELL IF THESE METALS ARE ACCUMULATED, FROM THE LONG OIL CHANGE, OR FROM POORLY WEARING PARTS. ALUMINUM AND IRON TEND TO SHOW PISTON SCUFFING, WHILE COPPER COMES FROM BRONZE/BRASS PARTS. SILICON MAY SHOW ABRASIVE DIRT GETTING PAST THE AIR FILTER, SO CHECK THAT (THAT WOULD CAUSE HIGH WEAR). THE TBN WAS 1.9, LOW. TRY 5000 MILES.
MILES ON OIL: 10,391
MILES ON UNIT: 113,967
SAMPLE DATE: 10/22/2005
ELEMENTS IN PPM UNIVERSAL AVERAGES
ALUMINUM: 17 2
CHROMIUM: 3 0
IRON: 122 7
COPPER: 19 7
LEAD: 6 3
TIN: 2 1
MOLYBDENUM: 67 52
NICKEL: 1 0
MANGANESE: 0 0
SILVER: 0 0
TITANIUM: 0 0
POTASSIUM: 2 1
BORON: 43 64
SILICON: 27 17
SODIUM: 12 7
CALCIUM: 2124 2284
MAGNESIUM: 17 161
PHOSPHORUS: 574 722
ZINC: 712 722
BARIUM: 0 0
SUS VISCOSITY @ 210 DEG.
SHOULD BE 59-68, IS 64.8
FLASHPOINT IN DEG. F
SHOULD BE >365 , IS 395
FUEL %
SHOULD BE < 2.0, IS
ANTIFREEZE %
SHOULD BE 0, IS 0
WATER %
SHOULD BE
INSOLUBLES
SHOULD BE
My driving style is hard. I commute 8 miles each way to work in heavy traffic and tow my trailer to the desert about a dozen times a year. At around 100k miles I did an AutoRX treatment. I did use a copper crush washer during the last oil run instead of the fiber washer that I am supposed to use. Could this have affected anything?
What do you guys think about this. I am concerned about my motor. This is the first oil analysis I have ever done.
Ken
ALUMINUM: 17 2
CHROMIUM: 3 0
IRON: 122 7
COPPER: 19 7
LEAD: 6 3
TIN: 2 1
MOLYBDENUM: 67 52
NICKEL: 1 0
MANGANESE: 0 0
SILVER: 0 0
TITANIUM: 0 0
POTASSIUM: 2 1
BORON: 43 64
SILICON: 27 17
SODIUM: 12 7
CALCIUM: 2124 2284
MAGNESIUM: 17 161
PHOSPHORUS: 574 722
ZINC: 712 722
BARIUM: 0 0
FUEL %
SHOULD BE < 2.0, IS
ANTIFREEZE %
SHOULD BE 0, IS 0
WATER %
SHOULD BE
INSOLUBLES
SHOULD BE
Ken
