Here's another VOA of this oil. I'm posting this because of the slight inconsistencies we've seen among the previous 0W-40 VOA runs. There are three other 0W-40 VOAs that I could find (I don't feel the Belgian 5W-40 "System-S" is valid for comparison). Of these, two (both from Scaeffer's Labs) showed some moly & one (from Oil Analyzers) showed no moly. This sample was run by a different lab (H.O.Penn), so I thought folks would like to see what they came up with.
I bought a bunch of this oil (about 6 changes-worth; don't ask) around Nov '02, but it was all loose stock. I put 4qts in my car in Dec '02, & then sent in this sample (from an unopened bottle) in Feb '03. I didn't think to track lot numbers. Sorry. If it's any consolation, I'll be using this opened bottle to top up the crankcase when I take my first UOA sample & change the filter at 5k miles.
"Number of particles up to 5 microns in size equals 1917"
and,
"Number of particles up to 15 microns in size equals 24"
The ISO number is a type of quick-reading "equation," where particle counts are broken into ranges & assigned values. These values are then placed together into a single equation, with 5um read first & 15um read second. This way, you have a quick idea of particle density without having exact numbers. (If you're not confused, ask me to 'splain it again...)
As for the Particle Count reading, I was told it was per milliliter, & should be read as,code:
Copper: 2
Iron: 3
Chrome: 0
Lead: 2
Aluminum: 6
Silicon: 3
Molybdenum: 73
Sodium: 15
Calcium: 2813
Tin: 0
Potassium: 10
Magnesium: 5
Zinc: 903
Water: Negative
Viscosity: 14.9
Part Count: >=5 1917
>=15 24
ISO: 18/12
and,
