It's pretty clear to me that virgin oxidation value does give you some idea of the ester component.That oxidation reading is wild isn't it.
Greater than >30 Ester (Percentage %)? They state 50% on another sheet? If you've seen it I'll take your word for it.Here is Valvoline VOA for Restore which Valvoline specifically states is 50% POE.
Virgin Oxidation - 110.
It is not 100% accurate because there are so many different esters, but the numbers I have posted match up extremely well to the point that it's hard to say otherwise IMO.Greater than >30 (Percentage %)? They state 50% on another sheet? If you've seen it I'll take your word for it. Just curious
Just dug up this pdf on this restore oil
Wow, that’s a pretty big drop in fuel%… was there any significant change in usage? If not, that (to me, at least) would be a pretty powerful signal that the rings weren’t sealing very well prior to Restore, and then your longest run listed also has the least fuel?I have 3 gals of Valvoline "Restore" I plan to use on one or more of my high mileage gasoline engines. Here's a used oil analysis I found.
I'll send a virgin sample in for a baseline when the time comes.
You might be on to something here...But if they run it again under the same situation & it comes back at 4% it's not working very good or it's another mechanical issue. lolWow, that’s a pretty big drop in fuel%… was there any significant change in usage? If not, that (to me, at least) would be a pretty powerful signal that the rings weren’t sealing very well prior to Restore, and then your longest run listed also has the least fuel?
It wouldn't surprise me with those guys LOL.There is actually a used oil analysis on mobil jet oil running in a car on Russian oil club![]()
That report is not about anything I own. It's a report I found on the interweb somewhere? I don't know who it belongs too?Wow, that’s a pretty big drop in fuel%… was there any significant change in usage? If not, that (to me, at least) would be a pretty powerful signal that the rings weren’t sealing very well prior to Restore, and then your longest run listed also has the least fuel?
What "terrestrial" global vehicle requires a 5 cSt@100C engine oil with only one base oil (POE) and three chemical components?There is actually a used oil analysis on mobil jet oil running in a car on Russian oil club![]()
don't know, ask the Russian's. Still good uoa with only 1 ppm ironWhat global vehicle requires a 5 cSt@100C oil with only one base oil (POE) and three chemical components?
A Gulfstream JetWhat global vehicle requires a 5 cSt@100C engine oil with only one base oil (POE) and three chemical components?
Here are the Priolube 1973 specs mentioned in the patent.It is not 100% accurate because there are so many different esters, but the numbers I have posted match up extremely well to the point that it's hard to say otherwise IMO.
I can try and find the Valvoline Restore article that mentions that it's 50% POE.
Here is the patent for it:
https://patents.google.com/patent/US20170029734A1/en
20% PAO
50% polyol ester (POE)
10% alkylated naphthalene (AN)
0% viscosity-index improver (VII)
20% additive package
Lada NivaWhat global vehicle requires a 5 cSt@100C engine oil with only one base oil (POE) and three chemical components?
