MolaKule
Staff member
True and I have modified the original question to:A Gulfstream Jet
What "terrestrial" global vehicle requires a 5 cSt@100C engine oil with only one base oil (POE) and three chemical components?
I don't think Mobil Jet II qualifies as 5W30 to 15W40 engine oil.Lada Niva
Drink enough vodka and it seems like a good idea. Very forward thinking, it's almost like a 0W-12 without additive pack.I don't think Mobil Jet II qualifies as 5W30 to 15W40 engine oil.
Took me by surprise !!!There is actually a uoa on mobil jet oil running in a car on Russian oil club
Just for fun I found this on the Russian Oil Club site.
So Arthur you haven’t properly introduced yourself here. You’re new it says? Where are you from? What’s your background?btw, may highly recommend this exceptional forum that offers a wealth of fascinating information. Although a translator (Google Translate) may be required, it's well worth the effort. Notably, this forum stands out as the only platform on the internet that delves into the true origins of the numbers 20, 30, 40, and 50 in the SAE marking, revealing their original significance in terms of time (in seconds). Moreover, this forum provides unique insights into intriguing cases such as the correlation between the use of viscous PAO base and the infamous Mobile AV 1 disaster with showcases featuring vintage Mobil AV 1 advertisements that cleverly play with words like "synthetics" and "sin" -
And you have a connection to silver?
It's pretty clear to me that virgin oxidation value does give you some idea of the ester component.
- Mobil Jet Oil: Virgin Oxidation 219 (100% POE)
- Valvoline Premium Restore: Virgin Oxidation 110 (stated to be 50% POE BY Valvoline)
- Red Line: Virgin Oxidation (90-134) (Dave Granquist said up to 40% in some grades; I'm guessing 20-40% range)
- Amsoil: Virgin Oxidation (47-50)
- Mobil 1 ESP: Virgin Oxidation (38)
- Mobil 1 EP: Virgin Oxidation (B] (suspected AN's don't show up similarly)
As you can see, the amount of ester correlates very closely with virgin oxidation reading. It's not 100% accurate, but pretty **** close. It also matches what the Russian oil folks and Spanish YT channel have stated.
*Dave G. sealed it for me when he told me approximately how much is used in some grades (up to 40%)(RL's oxidation values range from 90-134).
I just realized I posted a VOA of this before.
The bearings are enclosed in "bearing cells" with the oil being cooled by fuel-to-oil and air-to-oil heat exchangers. Bearing cells do have a certain percentage of oil seepage.The thing to keep in mind with this type POE turbine oil is its application in turbine engines and how different it is compared to a reciprocating gas engine. In my experience, the turbine oil cools (primary application) and lubricates roller and ball bearings that support the engine shafts. These bearings are enclosed in separate sumps (dry sumps), that are isolated from, and NOT exposed to combustion byproducts. The fact that they are not exposed to combustion byproducts allows them to be formulated in a more "raw" manner, reducing the necessity for additives. Since they are exposed to high temperatures of the materials and parts involved, the necessity for POE base stock makes sense. From what I have experienced, the oil used can continue to be used for many hundreds, or thousands of hours before analysis will require the oil to be changed.
Was watching them top up a GE-90 in Tokyo - the little Mobil Jet containers looked like cans from the 60’s …The bearings are enclosed in "bearing cells" with the oil being cooled by fuel-to-oil and air-to-oil heat exchangers. Bearing cells do have a certain percentage of oil seepage.
While not exposed to combustion by-products, the bearing cells supporting the turbine (hot) section are exposed to high temperatures via thermal conduction. Topping-off of the oil reservoir is the usual procedure.
These special POE esters are the only ones capable of withstanding the operating conditions encountered.
I use Royco 899 gas turbine oil in my 2 superchargers, have for 15 years now. No bearing failures to date. Stuff smells terrible.
the ester used in Valvoline Premium Restore (assuming it is Priolube 1973) has only two ester groups, and a higher molecular weight
If I may inquire, in the context of supplementing a racing oil with a 15-20% ester, which do you believe would yield more favorable results: TOTM or TMPTO? While I personally lean towards TOTM, I must humbly admit that my expertise in esters is limited. I would greatly appreciate your insights on this matter.
Depends what you want to achieve. Both have the same viscosity @ 100°C but differ vastly in Viscosity Index. TOTM (Tri 2-Ethylhexyl Trimellitate) has a VI of only 82 while TMPTO (Trimethylolpropane Trioleate) has a VI of about 190. As a result the TOTM will thin much more if operating temperatures exceed 100°C. TOTM is much more oxidatively stable than TMPTO and so is better for high temperatures and extended drains, but TMPTO has much better lubricity and less effect on seals. Also TMPTO is biodegradable while TOTM is not.
If the oil will be changed after each race and the engine rebuilt frequently, the oxidative stability of the ester @ 15-20% should not be an issue. Under those circumstances I would favor the TMPTO for its lubricity benefits. Another alternative is Priolube 1973 (Neopentylglycol Diisostearate) from Croda which combines high lubricity with good oxidative stability, high VI, biodegradability, and seal compatibility.
Thank you very much. I chose the option that seemed to have less tension. Tension is a function of polarity, although I may not have the exact data. If we were to compare all three of these esters in terms of surface/interfacial tension, which one would have the lowest value (steel surface)?
