MMO UOA?
texas
Hey guys,
I ve been using MMO in my oil and I wanted to know if any one here has sent their oil with MMO for a used oil analysis, what were your findings?
Thanks!
Originally Posted By: gs300tx
Hey guys,
Thanks!
There were a few very good reports in the used oil analysis section. You can give the search engine a try and see if you have better luck than I did trying to pull them up. HTH
The used oil analysis posted didn't include TBN. That is the huge question mark with MMO. It definitely didn't hurt wear metals or thin the oil out too much but w/out the TBN, it is hard to say if it affects the longevity of an oil.
It isn't going to hurt at all if you keep an OCI short.
Maybe someone will at some point do a used oil analysis with MMO and ask for a TBN check. The used oil analysis posted were pretty good IMO. Maybe in time someone will post another used oil analysis with MMO and include a TBN check.
Hey guys, Im runnin MMO and conventional 5w30 oil right now ..2k on the oil and MMO at this point. I have requested the KIT from blackstone, when I get it I will get the UOA along with the TBN..just a matter of time now
unk bulk 5w-20 w/ 1 qt of MMO. 5.7 Hemi 4,133 OCI
tackleberry625
Loc: South, FL Comments from Blackstone:
“Universal averages show average wear for this type of engine after about 5,100 miles on the oil.
This oil wasn't in use that long, and wear metal accumulation was low and in the correct balance, so no evident problems with internal engine components using the oil exist. Silicon was much higher than average. It can represent either harmless silicone-based product, or dirt. We doubt it's dirt since wear looks okay, but we recommend checking air filtration, just in case. No fuel or signs of coolant were present, and low insolubles show good oil filtration. Looking solid!”
2008 Dodge Charger police/pursuit vehicle. Mileage on vehicle is 24,200. Mileage on oil was 4,133. Oil filter was Napa Gold. Unk bulk 5w-20 oil with 1 quart of MMO added at the beginning of the OCI when the oil was put in service (6 quarts oil, 1 qt MMO = 7 quart sump). During the OCI, the vehicle was pushed hard on a daily basis. 10-15 idle to full throttle take offs and then redlines during each time on each shift. At times, the vehicle idles for hours at a time. Universal Averages are on the right.
ALUMINUM 1/2
CHROMIUM 0/1
IRON 11/19
COPPER 39/41
LEAD 1/1
TIN 2/0
MOLYBDENUM 13/74
NICKEL 0/1
MANGANESE 1/1
SILVER 0/0
TITANIUM 0/0
POTASSIUM 8/2
BORON 12/45
SILICON 30/9
SODIUM 19/21
CALCIUM 1687/2237
MAGNESIUM 14/76
PHOSPHORUS 641/646
ZINC 764/789
BARIUM 5/0
SUS Viscosity @ 210°F – 51.9 / 46-59
cSt Viscosity @ 100°C – 7.86 / 6.0-10.2
Flashpoint in °F – 400 / >355
Fuel % - < 2.0
Antifreeze % - 0/0
Water % - 0/ Insolubles – 0.3/ NO TBN
Edited by tackleberry625 (04/15/09 09:07 PM)
Edit Reason: typo
_________________________
Marvel Mystery Oil believer since 1993. Auto-Rx believer since 2008
