This is for Honda GXV140 engine which is approximately 137cc OHC. I put about half oz of MMO in the cylinder. Because spark plug is almost horizontal on this engine, it was not easiest to inject MMO in to the cylinder. I used a turkey baster with a small tube attached at the end to put about 1/4 oz of MMO twice in the cylinder. I do not know how much of that dribbled out. I put the spark plug loosely back on.
I am going to let it soak for a week. Wish me luck
This engine has never given me problem during the starting. Even after a season, it starts on the first pull. But it really lacks the power and bogs down very easy. I have done almost everything that can be done to it without taking it completely apart. It had every gas cleaner imaginable through the tank and through the carb throat. I should have done compression test but if MMO makes a difference, it would be obvious during the mowing. The next step is going to be Kreen soak and failing that I will be trying Restore.
Because the engine starts and runs great, I am resisting to take apart the carburetor. Besides, I do not know if I have the skill to put it back together.
- Vikas
- Vikas
