quote:
But as stated above, who knows if the mix really is better than an off the shelf oil?
In my opinion, depending on the concentration of the "good oil" into the "lesser oil", the worst that could happen is that you end up with an oil very very slighty better or equal to the lesser oil.
Guys, the fact is that ALL base oils (at least the common ones such as Grp I, II, II+, III, IV, and V-[the commonly used esters]), are ALL compatible with each other. In fact, many if not most oils are a combination of 2 or more of these different groups. A good example was the old M1 Tri-Syn, which has been said to be Grp IV and 2 different types of Grp V bases.
Also, additives used by the well known oil blenders are all the same and are of high quality and proven through testing and everyday driving. In other words, Pennzoil, QS, Castrol, etc does not used any "weird" additives such as clonirated parafins, graphite or baby oil. They all used the same moly, boron, zinc and phosphorous, althoguh some may or may not contain ALL such additives in a single formula. In fact, as I understand it, a company named Lubrizol supplies the additives to most oil blender, including Amsoil and Mobil.
In conclusion, in my opinion, as long as you stay away from stuff like Slick 50, Z-MAX, Prolong and others and stick to well know oils, you will be OK!!
[ September 22, 2004, 10:28 PM: Message edited by: Last_Z ]
