There are a few reasons one might "mix" oils.
1) necessity
2) desire
3) inadvertent
There is no terrible oil chemistry accident waiting to happen if you mix brands of similar grades/specs. That's an old myth that seems to have resurfaced recently. One of the main points of API certification is the ability to assure lubricant compatibility. Using a CJ-4 with a different CJ-4 is about as compatible as you can get from different sources.
If you mix a CJ-4 Delo 15w40 with a CI-4 10w30 Rotella, you'll end up with some hybrid viscosity and additive package that confounds the AR Bitog'er. But there is no reason to expect it will create some massive clash of molecules that results in abrasive tar ... Mixing compatible oils will never hurt your engine, as long as you stay in a reasonable grade and the add-pack is not grossly outside the realm of "normal" to the equipment OEM. Since CJ-4 fluids are backwards compatible, there's really no risk here at all.
You can even mix a non-detergent 30 grade with a 5w-20 PCMO. There is little reason to expect the oil will self-consume and subsequently auto-ignite in a fireball. It will make the lube unworthy of long term use, though. Is this advisable? Depends upon how desperate (or adventurous) you are. If I were in the middle of nowhere, and my low oil level light came on, and I needed VOLUME to simply get the oil level up to a safe point, I'd use just about anything to get me home until a proper OCI could be done. There is little very risk in short term exposures, even using the "wrong" oil. I've also been known to mix brands/grades when topping off a low-tech ol' skool valve-in-block B&S engine. But the risk is low there for such splash lube engines.
My point is that mixing is like everything else. You may HAVE to do it to get home. So do it and don't worry about it. Or, you may be mixing to clean up some left-overs from the garage. Either is ok. The important thing to note is that short term mixes can be done with about anything. But long term mixes need to be with compatible fluids.
One important thing to note; mixing will, however, distort your used oil analysis. If that's not a concern to you, mix away.
