Mixing Dex3 with stock PS fluid
Australia
Hello all
Decided to change out the PS fluid on some of our cars since I have no idea when it was last done. The two I was looking at doing were a 2003 Mazda 323 (Protege in the US) and a 1994 121. Manuals for both of these claim that they take Mazda MIII or equivalent (such as DexIII) so I purchased 4L bottle of Shell Spirax MD3 which is a DexIII fluid. Something I didn't think of beforehand was that I was probably going to use the drain/refill method which won't get 100% of the old fluid out and I have no idea what fluid is already in there, however it is probably the same fluid they, left the factory with.
Although it's a bit vaugue because I don't know what's already in there, my question is should the Spirax react in some way with the small amount of old fluid assuming it's Mazda MIII? I don't mind using up a lot of the new fluid to ensure most of the old stuff is out since it was cheap-ish, and if need be I can do a line disconect to try get even more out.
Cheers
It will be fine. I've done it on all my vehicles. All of them that I got used with black power steering fluid I used ATF and it worked fine. Sometimes it would make noise because of the mixed fluids but after I got more fresh fluid in it always got better
Good to know, cheers.
Did both today which was simple enough. Neither fluid was particularly bad however the 121's was much darker than the 323's.
