Hi,
I've heard all sorts of methods to change the power steering fluids such as using a turkey baster or swtiching the ignition on, turning lock to lock while pouring new fresh fluid. I don't like both method as the first one doesn't replace all the fluid and the second one is "dangerous" as there is a risk to run the pump dry.
So I'd like to propose something but I need you expert knowledge to know if this will work or not. The main idea is similar to the one of starting the engine and pouring fresh fluid in the reservoir while avoiding to let the level drop too low. As this is quite difficult to achieve when the engine is running, I propose to MANUALLY crank the engine so that it will make the PS pump "work" slowly. Therefore, the fluid level in the reservoir shouldn't drop too quickly and it should be easier to pour in fresh fluid while the old one is draining out from the disconnected return line.
Do you think this would work?
