Mix ATF conventional and synthetic?
Virginia
I'm driving a 2003 Chevy Express 3500 purchased used and want to change the ATF.
I have no information on what ATF is in the transmission now.
I am getting conflicting information on use of conventional vs synthetic ATF when draining and replacing the filter and fluid.
I am not getting any feedback on how to identify a fluid as conventional vs synthetic and assume it will require a serious chemical lab analysis.
First I am warned off of doing a flush because of the "grit"(?) in the gears is keeping it running smooth.
- But then others suggest to drain, replace, drive and repeat to get the most new fluid in the transmission.
-- That seems like a flush.
The Service Manual calls for DEXRON III which is conventional.
A local dealer uses DEXRON VI ATF; full synthetic for everything.
- Dealers in my opinion are not concerned with more than getting paid in the short term and stonewalling problems in the long term.
I have reports that synthetic can be used to replace conventional but not visa versa.
- But I was not intending to flush so whatever is in the trans now will mix with the new.
ACDelco does not recommend replacing conventional with synthetic.
- Some comments take ACDelco's stance as a cover-their-ass position so they can Pontius Pilate any complications.
Too many comments take whatever the local mechanic tells them to do.
Can anyone provide an in depth assessment of mixing ?
There is no real issue with mixing the base stocks.
Assuming the van has never had an ATF refresh, then the old Dex IIIh is in there currently.
You can use any fluid that would be backward compatible with that Dex IIIh. And that's a slew of products marketed as "Dex/Merc", or "D3/M", etc from a reputable source. The Dex IIIh fluid is no longer licensed, but many companies still make a reasonable effort to comply with the former fluid.
You could also use Dex VI. Or Maxlife syn ATF.
Where is this statement by ACDelco?
And DEXRON-III does not specify a base stock composition. It’s a performance specification. But it’s also a superseded license specification as dnewton3 notes above. The official supercession is DEXRON-VI which is often a synthetic base. No covering of posteriors is needed, DEXRON-VI is a better license and a better fluid in every way.
I’d use Maxlife since I use it in every recommended application. But maybe that’s just me.
Maxlife and others should work fine but I've had the best experience using castrol transmax high mileage since it made first gear shift like brand new on two old 4 speeds. My sierra was a touch delayed but not anymore while the yukon was slightly quick but unnoticeable feel wise though you could hear the rpm drop quickly shifting into second when it was cold. when warmed up it was normal.
Looking up a pds after using it since it was recommended to me I saw that it has the highest KV100 being 8.0 so maybe that helps? or the additive pack is better for older more worn out transmissions as mine have over 600k combined with no rebuild so that could be it. I get mine from home depot in store but check if yours has it.
https://www.homedepot.com/p/CASTROL...atic-Transmission-Fluid-1-qt-151DD0/205159600
https://www.amazon.com/Castrol-Transmax-Mileage-Automatic-Transmission/dp/B00DILUC6U
I would run Valvoline MV Import synthetic or Valvoline Extended Protection ATF which are both synthetic with a cst closer to Dex3. Maxlife atf is a little thinner, 1cst but is great fluid in older GMs as well. You can mix and/or run a synthetic in a older dex3 specd transmission no problems. I have had Maxlife in my 93 C1500 for >40k miles now with no issues. I was d&f with the MV Import syn but zon raised the cost to same as EP and $10/gal more than Maxlife so no real point. I had an Element that is was use the Import in as well but sold it. I will go with Maxlife again or EP at the next d&f.
Castrol also has very good fluids for the dex3s as well. Even Supertech Dex3 HM is a good option for it, just change is at 30k vs 50-60k intervals. id run whatever you can just keep it fresh and I'd also add Lubegard Red to it as well. It helped significantly with my harsh 1-2 gear shifts in several gms.
dnewton,
Education on “base stocks” needed.
Assuming what is in the van now and mixing is the primary question. A
kschachn,
The information from ACDelco comes from a CS conversation with a Parts Specialist.
On the ACDelco site and on retail sales sites DEXRON VI is ambiguous as to if it is synthetic or not. Some bottles say synthetic, on others there is no mention.
I am still hoping for some content on mixing.
dnewton,
kschachn,
You can mix them all day long.
In order to meet the better and more stringent requirements for DEXRON-VI there must be synthetic base content. This is why it is important to go by performance not by supposed base stock. The later license has better oxidation resistance and shear stability than any previous license. It is a better fluid no matter how you look at.
And a “a CS conversation with a Parts Specialist”? Okay sure.
A 4L80E will not care one way or the other....If it fails....It was going to fail regardless!!
Drop the pan & do a analysis on what you see.
If there is any delay into drive or reverse....The unit has mechanical issues that CANNOT be resolved with magic pixie dust!
  • Like
Reactions: D60
I'm cheap so if a trans was originally spec'd for good ol' Dex/Merc I'll run that if it's cheaper. Quite often sales on DexVI/LV are better, so I'll run that. Or Maxlife if that's cheaper.
And I'll definitely mix all three of those and top off with any one of them -- again assuming this is an older trans that can handle Dex/Merc
I think for most of us regular clean fluid is more important than anything.
Get a pan with a drain and do a spill 'n fill every fourth, fifth or 6th oil change (depending upon your OCI and other factors). Clean fluid keeps autos happy 99% of the time.
  • Like
Reactions: wlk
It won't really matter what you use so long as it's an appropriate fluid, DEX VI has been backspec'd for almost all transmission applications calling for a prior Dexron Spec. Synthetic fluid should be superior to conventional, if you're worried about DEX VI being thinner you can always use an Allison TES-295 approved fluid, TES-295 is essentially synthetic Dexron III meant to stand up to extended drain intervals in HD trucks. You could also use TES-668 fluid, while Allison says it's backwards compatible in all their transmissions I'm not sure if it's a great choice for older GM transmissions when TES-295 has been regarded as one of the best fluids you can use in applications that originally called for DEXRON III or prior.
As a mere mortal, dare I ask if MaxLife is suitable for Toy WS or Honda DW-1?
Asking for a friend who services a lotta those cars. Thanks in advance...
@JeffKeryk - maxlife is well-accepted here for Toyota and Honda. I’ve personally used it in several Toyota/lexus products with factory-fine results. i just bought two gallons this week for vehicles outside of my family that I look out for. However, I was personally bitten with transmission degradation when used in a Honda product that became almost undrivable over time, and partially got better when I got it all out - though never back to great. the fluid was definitely not good in that trans. There is only one other BITOG member I know who experienced this, so doesn’t seem common. Yet, for that reason I’m a little hesitant to use maxlife in Hondas and vastly prefer using amsoil. Really, if it’s my own vehicle I tend to spring for amsoil anyway. I’ve used it in Honda, Toyota, Chrysler, Volvo, Buick and Suzuki without issues.
I think if conv & syn ATF mix you'd get a syn blend, which should be fine. My local trans shop doesn't worry about them mixing. Also, when I asked them if I need to continue using conv ATF in my Buick, they said syn is fine.
I'm not an expert, but I think it's fine.
i used maxlife dex vi in my 2003 silverado 1500,4l60, that originally had dex iii, i could notice a difference in the way it shifted after the change ,i could tell the diffence between the 2 by the way they smelled , dex iii has a sweet pleasent smell to it , and the dex vi has a not sweet at all smell to it , almost a repulsive smell to it , i picked up some valvoline synthetic dex vi on amozon sale last fall, like 32 for 6 quarts , it was in the sales and promotions bitog forum
Continued digging brings me to this.
- I was really thrown by a non-response to the three emails sent to ACDelco after being told verbally by CS to NOT MIX conventional and synthetic ATF.
-- Up to now I had a high degree of confidence in ACDelco. I do not understand why ACDelco has nothing to say for themselves now.
- I find DEXRON VI comes in a conventional and synthetic form.
- Another ATF producer, Valvoline, was much more forthcoming with evidence that DEXRON VI ATF is the only approved fluid for warranty repairs to GM transmissions ... requiring DEXRON III ... . And including my vehicle in the list.
-- Valvoline clarifies that it is the ATF Specification that matters not the conventional or synthetic form. If it meets the specification, it meets the specification.
Note that this all relates back to my 2003 Chevy Express 3500 requiring DEXRON III which was conventional.
It's not required, and base stock composition (whether conventional or synthetic) was not part of the DEXRON-III license. It was based on specific performance parameters, which are exceeded by DEXRON-VI.
What ever is in there now, put back new. Very simple. The owners manual should tell you what to use, or sometimes the dipstick will. Don't play games mixing fluids. You can also find out what to use on the internet. The specific fluid is meant for the clutches and seals, to keep them working properly, and keep the seals soft and pliable.
Calling/Emailing a company like that is bound to get you a whole lot of not much. They don't know. They're just a parts supplier that places orders for things that meet specs. They're not a vast knowledgebase of what works where.
@clinebarger would have the edge on advice in this thread. He's rebuilt and worked on more transmissions than probably anyone else here. What he says is good advice.
--Edited to Add--
Besides. With Group III+, GTL's, PAO's and Esters having to have different things added to them for additive solubility......what is a synthetic, and what is a conventional these days? All of them have parts of the other in them, so why worry. If it meets the performance spec you need, have at it.
  • Like
Reactions: wlk
The fact is....The 4L80E is not picky with ATF......Maxlife, Dexron VI, & TES-295 are all good ATF's for this unit with TES-295 having the longest service life.
Dexron III is a obsolete spec & if you have a Transfer Case, Manual trans, Or Power steering system that calls for it.....Use TES-295.
I wouldn't waste a bunch of money on a 20 year old unit with unknown service history, Use Dexron VI or Maxlife......whichever cheapest.
I've been using Mobil Dexron VI for a while now (Been through two 55 gallon drums), Use it in most 4L60/4L80 builds & all 6L80/6L90 builds.
