Mitsubishi MZ690116 cut open
Texas
2017 Lancer 2.4l on for 6~months, 3k~ miles. Used with 0W-20 Total Quartz 9000.
PH2867XL & Pennzoil Platinum 0W-20 went back in.
Looks very similar to the Toyota Thai Denso oil filter. Been a while, but member on the Mitsu/Evo forum did some efficiency testing on the Mitsu using same procedure as a member here followed. Result was pretty much in line with what's known about Asian filter efficiency, that is they don't put an emphasis on it.
Thanks for c&p.
Made in USA
Source or citing for that? Though a different application, linked vid shows Thailand coo. Identical construction type.
Thanks for c&p.
That is a Denso oil filter. Been using them for years.
Thanks for c&p.
