Hello everyone.
My names John.
I have a 2001 Dodge Caravan 2.4 Liter 4 Cylinder Minivan.
I got a check engine light back in September, and I got the codes scanned and it came back as a P0303 code which is cylinder #3 misfire. I replaced the spark plugs and wires and code came back, I then replaced the fuel injectors and the code went away and so did the check engine light. 3 days later the light came back and this time it was a cylinder #4 misfire. Since then I have replaced the following but yet still I have a check engine light:
I replaced:
Plugs, wires, coil pack, injectors, fuel rail, fuel rail wiring harness, flushed oil and filter, flushed coolant and thermostat, unclogged and cleaned the EGR, map sensor, throttle position sensor, I even went to Midas and got the Valve cover gasket as well as the spark plug tube seals replaced and yet I still have a check engine code and light. Now the code comes back as a pending P0304 but I have more power ( I can hear it and feel it ).
Is there anything I am missing? Does anyone in their experience know of something that I over looked or something else that could cause a P0304 code and light?
I asked the mechanic at midas and he says he does not see anything major wrong with the car, but he didnt really look into anything besides the cover gasket he replaced.
I asked a different mechanic and he said sometimes light comes on in error like the computer could be back. I told him that my check engine light is on steady in driver but blinks in park and he said, when the light blinks it is time to plan the funeral. Can anyone validate this?
Thanks in Advance.
My names John.
I replaced:
Thanks in Advance.
