Side notes: Mileage with 15w40 was approx 22.5. Mileage w/20w-50 was 23.365 ..which is very close to the vehicles peak mpg ever recorded which was 24+. I can't find my exact fuel/miles figures for the 15w40 at the moment and the difference isn't enough to be called significant, but the last trip I controlled enough of the variables to feel that it was very accurate. I'll swap out the 20w-50 today and put in the 5w-20 and do the exact same run and see what it yields. Temps are comparable and they're very close back to back tests ..so vehicle condition shouldn't have degraded in any other area (tune, etc.).
Now this will only show the difference the viscosity makes in a vehicle doing 70-75 mph for a very decent run. One could easily argue that under that speed, parasitic losses due to viscosity could be trumped by shear air resistance ..especially for a mini-van of this vintage ..but I will present the data FWIW.
(brief pause for me to get motivated)
Well, the 5w-20 is in. Valve train is somewhat noisier (this was normal) with a few random ticks for no dam% good reason. The stuff went in thinnner than the 20w-50 came out at (warm). The 5w-20 would have won a time trial between the two.
Another side note: Since my Auto-Rx treatments ..I've seen nothing collecting on my magnetic drain plug. Which I'm not truly certain about since I never really developed a good technique for getting the stuff off the plug (you don't dwell on this stuff too long when you're changing oil -especially on a 100k+ vehicle). After the Auto-Rx treatments ..the plug cleaned itself ..perhaps some function of polarity of certain bonding agents in the various oils (mostly HDEOs) ..who knows.
Whenever I went to clean it with a paper towel ..the stuff would just jump back on it as I slid the towel off of it ..sorta like magnetic graphite.
Now if after this run of 5w-20, which I will keep in indefinitely in the absense of any "warnings", it would be interesting to see if any additional (new) stuff is on the magnet (cue Twilight Zone music - what could it mean
Now most of this is
..but I figure if we're going to all this trouble and are swapping oils like underware ..we might as well piggyback as many tests as possible just to see what happens "while we're there" type thiing.
I'll probably switch back to a heavy weight (the 20w-50 worked well) when we reach some saturation level in the filter ..so far we haven't figured out any definitive mileage limit on the filter (5000 miles has been suggested). I also have a 9k used filter that Ugly3 has sent me (a PureOne as well) that can be swapped in for a short time just to see what condition of saturation it's at and if the bypass valve has any frequency of use.
