Milwaukee M12 FUEL INSIDER Ratchet
Is it worth getting?
I've already got the Milwaukee M12 FUEL High Speed Extended Reach.
For sure the Gen 2 (if/when) released will be the one to rule them all.Thanks guys. I think I am going to wait on this one and see what Milwaukee will offer in the future.
I agree. Several examples of Milwaukee rushing something to market and then the Gen 2 is way better. Mid torque impacts, die grinders....I'm sure there are more that slip my mind.For sure the Gen 2 (if/when) released will be the one to rule them all.
I think the challenge is getting it to reverse remotely AND having a pawl mechanism for true hand ratcheting?The only real advantage that I can see is the "pass through" socket feature for working in very tight clearance quarters. Other than cost, I don't understand why most (all?) cordless ratchets don't have a forward/reverse rocker trigger switch instead of the conventional ratchet direction rotating switch on the head? If you ever had a fastener bind up during removal in a tight space, you would understand the predicament of not being able to reverse the direction on the head of a cordless ratchet.
